Trailer Electronic Brake Controller Question
Hi...
I just installed a Tekonsha electronic brake controller on my Dad's 2000 GMC Sierra 2WD (new body style). I bought the factory harness pigtail off Ebay and matched up the wires correctly (not color to color of course...)
I also installed the 40A maxi fuse on slot #1 under the hood. The problem is that I am not getting 12V on the power pin (red wire in factory harness...) Is there another fuse I am missing? I did a search on this forum and no one seemed to have a similar problem.
Any help would be appreciated!
Thanks...
Tom
In the fuse/relay center under the hood there is a red wire that must be hooked to the power studs. It seems like a lot of the early trucks without the factory towing kit weren't hooked up there.
Thanks... I'll take a look at that this week!
I appreciate the help...
Tom
OLD...Pretty sure the maxi fuse goes into stud #2 to power
up the wire.
Try that first....................
99. Is also correct. Some early year OBS trucks the power
wire under the underhood fuse box may be disconnected.
Do a search with the words "stud #2" and you will find the
info you need.............
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 885 Guests (See full list)
