Silverado Brakelight Troubles
BamaMule
I own a 98 Z-71 with a tow-lighting package, and recently both the rear brakelights have completely quit working....no blinkers, hazard lights, stop lights, or reverse lights. This started with the right blinker not working and is turning into an all-out blackout. I replaced the right grid that you plug the bulbs into and the bulbs. Nothing works... is this a wiring problem? If so...how can i fix it?
Check the T-connection at the rear of the truck where the trailer plug tees off from the tail light harness. It might be disconnected.
I got it fixed...where the wire harness clipped into the tailight had a loose ground wire...so tightening the clip fixed everything. Thanks for the help. :crackup:
    Selfman
    Selfman
  • Who's Online   4 Members, 0 Anonymous, 591 Guests (See full list)
