2003 Silverado Wiper Problem
I just bought this truck a few weeks ago. Any, I went to clean my windshield today and assumed that the wipers would stand up and out of the way like all other cars. But when I did that the hook that ties to the tension spring popped out. Well it is impossible to get back in. So, I figured that If I removed the wiper blade I could do it. I took off the nut at the arm pivot but can't get the arm off. It is as firm as when the nut was on.
What am I missing? :)
I had the same problem when I tried to get my arm off. I never did get it, but my best guess is you'll need some kind of small puller to get the arm off of the post.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 347 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
