Am I draining my battery when hooked to my trailer
I pull a travel trailer with my 2002 GMC 2500HD D/A. I occasionally "dry camp" without plugging the trailer into any electrical source. I did this recently, for four days straight, without disconnecting the cable from the truck to the trailer. Was I draining my truck battery in this configuration?
I used the truck (without starting it) to charge my cell phone battery for about 5-6 hours one day and the next day the truck started but the battery light stayed lit longer than it normally does.
It's hard to imagine that JUST charging the cell phone ran down the truck battery at all.
I need an answer specifically for my truck. On generic RV boards, I got a lot of "well, if you'd bought a Ford or a Dodge, they're wired so you wouldn't do that" kind of useless answers!
Thx
I believe the +12 in the trailer plug is not covered by the Battery run down protection... Simple way to test is to put something that will draw a steady load on that pin and see if it shuts down.
Not sure how experienced you are with camping.
First, I would assume that your camper has a 12v battery that it uses as a power source when you are not connected to 110ac. Is this true?
Most newer (1980 and later) campers have this. When you plug your camper into 110ac there is a charger in the camper that charges your campers battery. When you "run dry" which we call running self contined your are using power from this battery.
As for the truck connection . . . it depends on the age of the truck and if your RV plug was wired correctly or not. I will assume you have the standard 7 wire spaded RV connector. In that case the center pin (I think) is a +12v source for your camper (if it was ever wired correctly). A couple of simple ways to tell are
1) You can measure the +12 on the center pin with a volt meter
2) You can disconnect your campers battery and your truck connection. The lights in the camper should NOT work. Now plug your camper into your truck and check the camper lights again, they should work. If they do then your truck is wired correctly.
If your camper is wired correctly then every time you are driving (or your truck engine is running) you are charging your camper battery.
To answer your first question, "was I draining my truck battery in this configuration", the answer is yes, if your truck is wired correctly you were.
You are also correct about your cell phone. They use little or no power. Charging it shouldn't cause any problem at all. If it does I think you have other issues. I leave my radar dector on, cell phone pluged in and charging and my iPod plug in and charging over night and have no problem what so ever. In fact I don't even worry about it.
TNT
Thx
Yes you are using the truck battery. Without the alternator charging them, you essentially have your batteries wired in parallel. 1 or 2 on the camper and 1 or 2 on the truck depending on your configuration. Theoretically, (not technically, because of wire sizes and other variables that create resistance) you are draining your trailer and truck batteries at the same rate. If you have ample charge on your camper batteries, your truck should be OK. If you find that your camper batteries are becoming weak, I would start your truck and let it charge them up.
But the question becomes is the trailer circuit protected by the battery run down protection... like the head lights/interior lights
Nope, My enclosed trailer interior lights only work when plugged into the truck, because it does not have a usable battery (Just the small emergency, electric brake, breakaway battery). I have left them on for hours. When I went to start my truck, it turned over slow and luckily started. The Rundown Protection is essentially a 15 minute timer that shuts down the truck's accesories and lights. For some reason the +12V supply to the trailer plug is just a fused straight shot to the battery or batteries.
I do the same as you sometimes with a tent trailer. I installed a second battery in the truck and ran a nice switch to it (mfg = Painless). It will be in circuit during running. Out of circuit when off. I also can switch it into circuit when off to give jump start if ever needed. It works great.
To answer your question....Yes, when you leave your trailer hooked to the truck you are running your trailer off of the truck battery.
    Bulldogger
    Bulldogger
  • Who's Online   3 Members, 1 Anonymous, 728 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
