Squeak under truck
Driving to work today I had to go slow through some jersey barriers and heard a squeak under my rig. I stopped and it went away, sped up slowly to about 10mph and as soon as I started going it would come back getting faster as I would go. Sounds like a "rotating" noise, didn't sound like the wheels, maybe driveshaft squeak?? I just had my transfer case dropped and resealed at the dealer about a month ago. I plan on jacking up the rear end and putting the tranny in neutral then spinning the rear wheels by hand to see if maybe the front driveshaft is rotating. Suggestions are very welcome.
I've only dropped a driveshaft once, and that was a very long time ago. I doesn't seem to be that difficult looking at it but is there anything I should make sure of before tackling the replacement of the U-joints? I plan on taking care of this myself.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
