97 gmc sierra no power at 3000 rpms
I have a 97 sierra 1500 2wd that I am having problems with. When i drive easy I have no problems, but when I get on it up to about 3000rpms the power goes away not allowing me to accelerate. I check the code and it said it was the egr. I was wondering if anyone else has had that problem. If it is the egr what is the best way to clean it, cause it is like 200 dollars for the part. Thanks for your help
Have you checked your fuel filter and looked for other reasons that the engine may not be getting adequate fuel supply? An EGR failure should not affect drivability as severely as you describe.
