Power Supplies
OUMike
okay...so I built my gf a computer recently. I used the exact same case I had, except a newer version. The case was supposed to come with a PowMax 400 w power supply, but instead only 350 :) .
Now when she burns she stutters and its actually rebooted on her. I have a 420 watter and no trouble. I wanna replace mine too because mine sounds like a hellicpoter taking off.
I'm looking for a fairly priced power supply that is QUIET. What do you guys use? I was thinking Antec, Ultra and Thermaltake. How many watts do you guys figure we need? The goon at Fry's said 450, but again my 420 is fine. We're both running AMD64 3200+ processsors. I'm running SATA (or will be soon), and we both have 16 meg video cards (mine is DDR).
I was thinking anything above 400 should be fine. What do you guys think?
Thanks
Check the reviews at NewEgg.com, and disregard anything that a Fry's employee has told you.
I put in a 400W Rosewill PSU when I built my rig a few months ago. I don't understand why your girlfriend's PC is struggling with 350W. It makes no sense. How many harddrives and opticals drives is she running in it? I'm running a Athlon 64 3500+, a DFI motherboard, a fairly high-power HIS Radeon X800GTO video card, a DVD burner, and a 250GB SATA Barracuda. Her rig should have no problem with 350W.
Perhaps it's the burner? Or the software? Check for viruses or spyware, even if it was just built. Could be the harddrive too.
Was everything new when you built it or did you use some stuff you had lying around?
Thats what i was thinking. It should be fine with 350W. I have an Antec 420 in mine and its fine. Im running a P4 at 4.5Ghz, 2G OCZ RAM, 955x gigabyte royal MoBo, 2 SATA Hard Drives, 2 SATA Plextor drives, and an overclocked RadeonX850XT.
I think your power supply is the last thing you should be troubleshooting.
Everything in the box was brand new. The computer runs no trouble at all 99% of the time. The only time she says it lags is when its burning a DVD. She said it restarted her computer.
Western Digital 160 gig IDE hard drive
NEC DVD Burner
ABIT ULi Motherboard (same as me...it rocks)
granted...this comptuer only has 512mb of RAM. The more I think about it. This is probably whats causing her lag. I have a gig in mine and it doesn't break a sweat when burning, listening to music and sifting through the forum.
If she is running XP go into control panel click system and click on the "Advanced" tab. Click "Settings" under Startup and Recovery. Uncheck the box beside Automatically Restart.
So you guys think the lack of RAM was the cause of her lag? I havn't personally been at the computer while its doing this, its just from what she tells me.
In order for the system to reboot like she says it did, it woulda had to had a critical error. The computer is 100% stable to my knowledge. I'm gonna investigate the matter further. I don't want her to spend money on a power supply. I'm gonna mainly cause mine sounds like a helicopter. You TruePower guys....is it quiet?? My SmartPower Ihad a while back was really quiet.
I really doubt the RAM is her issue with the crashing. 512mb is more than enough to run XP and burn something, as long as she isn't running 3 instances of IE, listening to music, and playing a game at the same time.
The only way I see the RAM being an issue is if it's bad. Is it 1 or 2 sticks? If it's two, try pulling one and then burning. If it still crashes, try pulling the other instead. Still crashing, you've ruled out the RAM (since it's unlikely that both sticks are bad).
Have you tried running anti-virus software and anti-spyware software? That could be one of the issues.
I just have my doubts about the PSU. 350W should definately be enough.
Yea, I know the RAM is ok. It's the RAM I used to use in my machine. It's two 128 meg sticks. She said the only time it restarted on her was when she was ripping a DVD, talking to me (via IM) and surfing. Her claims of bogging I think are normal. I'm on it now, and it seems good. I'm just gonna ride it out. The computer is stable.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
