sfarzam Posted July 31, 2006 Posted July 31, 2006 I have a 2005 GMC Yukon and need to disable the door chimes....any ideas?
SoCalChris Posted August 5, 2006 Posted August 5, 2006 Aren't the door chimes controlled by the radio, and disabling the chimes would disable the radio? If you just need to do it temporarily (Like if you've got the radio on, and are working on the truck with the door open), you can easily disable it temporarily. Find the door latch, and push it in like the door is closed. When you need to close the door, just pull the handle like you're opening it, and the door latch will reset itself.
