I would like to find out what the combined gross vehicle weight is for my truck. It is a 1996 Yukon voretec 350 3:42's .(2WD) I am pulling a travel trailer with a GVWR of 6500 lbs. I have searched and can't find this info. Anyone know?
Thats a heavy load on that Yukon with a full load... I would'nt tow any more than 5K with that rig...
It depends on how far you are towing...if its not far, then take it easy and don't worry about it. Couldn't tell ya what the CGVWR is though.
If you list your VIN (or PM me with it) I can find out the GVWR for you.
5.7 with 3.42 has a Gross Combined Weight Rating of 11,000lbs..
I have a 99 burb with 3.73 and I tow a 6500 gvwr TT and I have scaled it at the local CAT and it is just 400lbs shy of its 12,000lbs GCWR. Short tows no prob long trips and big hills will fry the 4l60 and 10bolt rear if your not careful. Change to synthetic in the tranny and rear diff. I would also get the biggest tranny cooler (with a fan) regardless if you have a factory cooler as it is not big enough to keep the 4L60 cool with its working hard.. Good Luck
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
