fuel pump
Frank Wheeler
I was driving on the freeway and the truck stopped and would not start up.
I had it towed home to find the fuel pump fuse (20 amp) was burnt.
I replaced the fuse and the truck ran for a few seconds and the fuse failed again.
This occurred several times so I inspected all the wire connections and they seem good.
I reinstalled a30 amp fuse and tested to see if it wpould run without failing and sure enough it will run continuosly could someone suggest the culprit!
Thanks for your help.
Frank
