New engine no start
OneTon
First let me start by saying I generally deal with Fords, so I know there are some things I am unaware of when it comes to GM.
Now for the problem. 95' GMC K 1500 with a 350 and the Z-71 package. The owner experienced a MAJOR engine failure "the crank broke at the first journal". Engine has since been replaced with a long block assy. from one of the major chains. Everything is back in the vehicle. All harness and ground connections have been put back. Dist. has been installed and verified to be in phase with the cam. All plug wires have been triple checked for correct order. By the way this is a TBI setup.
Here's the fun part. When I go to crank it, turns over just fine, will not catch and backfires through the throttle body. It will turn over several times, and then backfire. I have gone through the dist. completely. New stator pickup and module.
What am I overlooking? :cheers:
Thanks, Wes
I am confused you have a 1995 TBI engine with a CMP and A CKP ??
crank & cam sensor I thought were MFI (multi port)and CSFI (Central Sequential Fuel Injection) type engine .....BUT its been a while
EDIT ...I was confused...by phased in with cam...thinking CMP
first any codes...Could the valves be to tight...have you checked cranking vacuum, looking for problem area's EGR vaalve and the TBI base gasket being damaged...Are the injectors spraying or dumping...set timing connector is it pluged in...you can try this unplug injectors and check timing with a timing light
use AC delco only
EDIT ...I am confused...by phased in with cam...
use AC delco only
Are you positive your plug wires are correct Gm numbers there cylinders differently then ford
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
