Vibration between 68-72
I had a clicky bad U-joint and decided to change both. At the same time a vib. showed up from 68-72.
The vibration is still there - Could the u-joint failure caused some damage? I even pulled it again and changed one of them I thought might be the culprit - no luck.
My tires have close to 70K on them and need changing too - I'm hoping that may be it.
Any ideas? Thanks
I am not a technician and am only making a good guess. The drive shaft is balanced as a unit as far as I know. You could either have a bad joint or possibly have the yoke or yokes turned 180 degrees from the way they were when they were balanced.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
