abs light after gearing
2004 gmc sierra z71 8" cst lift, on 35"tires/20"wheels
i just got my truck geared and now the abs light comes on
i reprogrammed the computer with hypertech programmer so my speedo is
correct, but the abs light comes on with a rear speed sensor code
any one have the same problem
Had the same problem with my 2003 when I went from 3.42 to 4.10. After numerous calls to Hypertech, they admitted that there were certian combinations that they could not completely correct, as the ABS computer would still see the transmission sensor spinning at a different speed than the front wheel sensors.
Their only suggestion was to keep lowering the tire size until the problem went away. This did work, but I had to lower my tire size from 31.5 down to 29.25. This cleared up the lights, but put ste speedo off.
I have since removed the Hypertech altogether and had the PCM tuned by Allen Nelson. Speedo is correct, no lights, and it runs better too!
so after getting tried of the abs light on(rear speed sensor code) i took to my local gm dealership and had them program just the tire size, there tech 2 can only do up 31'' tires, but no more light, just a speedo thats slighty off
Wait4Me Tune will also eliminate the ABS light, but make sure and mention it in your request!
Who cares if the speedo is off with bigger tires.
With larger tires the speedo goes SLOWER, it clicks miles over slower and basically stretches out your warranty.
Ding!
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
