Need Some Help Bad
swilliams1005
A couple things to check. Pull the vacuum hose off the fuel pressure regulator and check for gas. Probably the most common cause of a rich condition is the mass air flow sensor. I see you have a K&N filter. The oil from the filter can coat the wires of the MAF sensor and cause all kinds of problems. Take the sensor off and spray the wires with carb cleaner and toss the K&N. There is a GM bulletin advising not to use a K&N.
Swilliams,
If you decide to get new injectors, I'd suggest using five0motorsports.com. $300 for a complete set (I just replaced all 8 in my 98 K3500 with the 7.4 Vortec). They work great, and are fairly easy to replace.
I have heard about the problem with k and n and have removed it and cleaned the wire and still no help,,,i will check the vacum hose and repost on progress,,,
Swilliams,
Thanks for the hookup i will definetly check into it if i have to replace them thanks,,
