Aftermarket Catylic Converter Question
Ok...i always read all these posts about cat back systems from flowmaster, magnaflow or whoever, but i never hear aobut performance cat's
Is this because they are really expensive? Is it because if you get performance ones you cant pass emmisions? What kind of performance up grades are you looking at?
Since everything on your list is for bling there is no reason for a different cat. unless you change cams, do heads, headers and increase displacement or supercharge it. Just a waste of money.
When I added my stuff my cat was in need of replacement. I went with a Magnaflow cat. Picked up a couple MPG after cat a muffler.
Didnt your truck have the old bed pan style converter? If so there is a big difference compaired to the 1996 OBD2 converters. You probably saw a difference but the newer converters are very good.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
