Nav install HELP
92Rustang
I have a 05 lux touch screen. I installed it before I upgraged the amp. The unit works I used it for a week before I got the amp. AMP is out of H2.
I just finished the rewiring. The only thing I did different was use the pink wire oout of the back of the radio and connected it to pin a1 then coonected the pink wire oout of the old amp to B10.
When I turn the truck on I hear the DVD reading and the clock comes on for about ten seconds then goes off. I never get the BOSE screen. I did before the new amp was installed. I have tried the band button and the NAV button but nothing comes on. If I hit the power button the clock comes on for ten seconds then goes off.
I also did not change any wires to the RSA, but I unplugged it and still the same. I was not sure what to do about the RSA because oof the A/C controls.
Any help I hope I did not fry this thing. My only thought is maybe the amp needs to be programed?
I hope someone can help.
One more thing if I unplug the amp and turn the truck on it does the same thing. So it sounds to me that the amp is not turning on. Which is causing my problems with the HU?
The part # of the amp is like 884?or something close to that. I do remember hearing about problems with the H2 AMPs? Any clues?
I got it working!! I put the orange data back to it's orginal location behind the HU. I then spliced into the blue wire from the RSA and connected it to B10. Then I also spliced together both drain wires, before I only had one connected. That was it. Plug in the amp and door chimes worked. Fired up the hoe and radio came on and map appeared. Thanks for the help and info.
    busse
    busse
  • Who's Online   5 Members, 0 Anonymous, 731 Guests (See full list)
