Differences Between '03 & '06 Suburban
Hey, all
My hunt for a new Suburban continues! I'm currently looking at an '03 LT and '06 LT, both with equal mileage of 35K. Are there any major differences between these model years I should be aware of (or steer away from)?
As always, thanks for the help!!!
Regards
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
