Dimming Lights???
On my '01 1500 Silverado when I run the power windows my headlight slightly dim of and on like a strobe light......any suggestions on what this is???
The battery is only a month old.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
