Need advice on buffing
I just bought a Dewalt DW849 Buffer. Tried to use it last weekend but I'm not happy with my results. Although it did a great polish job, but I wanted to get some fine scratches and swirl marks out too, and this part of the job did not really happen. :ughdance: Of course guess I know why: To start and to be sure, I have only used polish and polishing wheels.
My question is what is a good combination of polishing material and wheel for my purpose (fine scratches and swirl marks). The most I'm afraid of is to cut too much paint e.g. at edges. So I don't mind using something less abrasive and going over the truck many times.
In case color matters my truck is black.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
