l460e TCU
stoudemire19
i have 98k k 1500 5.7 with the l460e tranny and i had to have the valve boddy and solenoids replaced but still seem to be having problems. the transmission seems at random times when taking off decrease in engine speed and raise in RPM's and the truck acts like it wants to move but just doesnt and then tries to recorrect itself back at shifting. could it be the TCU and if so what would be the cost
