Cost of tranny rebuild?
The tranny went out on my son's 2000 Silverado, 125K miles. Lost first and reverse and making noise. He took it to a shop (not a dealer) and after they opened it up, stated that it needed a comnplete rebuild and would be about $1900 complete. Anybody have a tranny rebuilt recently and is this a fair price in South Florida?
That sounds about right. Three years ago the Trans. went out on my '98 and it was gonna coat $1000.00 for a new torque conventor at the dealer or $2300.00 for a reman. with a 3 year 50,000 mile warranty.
The warranty is out but I have not had problem one with it. Plus, I liked having the warranty just in case.
Good Luck and let us know how it goes.
Reasonable price. The GM SERTA replacement is nice in that it gives you the nationwide warranty.
Having said that, I had FLT rebuild mine for 2K and that included lots of hardparts but no nationwide warranty. The company theat rebuilds all 4L60E's for GM is a customer of mine. They do a great job but it is an assembly line process and IMO not a custom rebuild.
Bottom line, if not adding HP to the motor, a standard rebuild will likely be fine especially with the warranty. If he has horsepower adders and drives hard, I strongly suggest getting it beefed up.
My 2 cents.
This is going to sound crazy but ive checked it out since i think mine might be on a slippery slope
theres a guy in san antonio doing it for 161$ plus parts said i could bring the parts thats cool too u pull out and put back in but still a helluva price just debating whether or not i wanna see just how long i can make it, its still allright but its gonna go someday
Gary, I have a good friend that just had his trans go out in an 2000 Burban with 115K. He is getting a locally owned trans shop to do it and they have told him between 1500 and 1700. He has a friend who is a tech at a GM dealership and he priced him a GM reman for 1400 which I believe is a good price. The labor to install was going to cost him about 150 at the guys shop at home.
He ended up choosing the local rebuilder simply because the GM dealership was almost 75 miles away and he did not want to pay for the towing. He also knows the local guy and really trusts him.
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
