GM oil life
royg
I am no expert on this but it is my understanding is that it uses your driving habits, RPMs, Miles driven, temp etc to calculate when to change. It is a decent system but it is not acutally reading oil condition to determine when to change. I have a Brother in Law with almost 300K on a 2000 6.0L and he has always changed his oil according to the monitor and cannot tell you how many miles it has on it when he changes it.
Personaly, I do not use mine but use the tried and true method or time and/or miles.
I generally use the light indicator to know when to change my oil and it usually comes on somewhere between 3k and 5k miles after being reset. I have always used the same regular oil though.
A friend of mine has an 05 Canyon and he uses the synthetic mobile 1 which is good for 15k miles. He has changed his oil twice now at 10k miles each and the light indicating a change is necessary still had not come on both times. Actually, he has yet to see it ever light up. This could indicate:
1. The system is not working properly
2. The system actually does know whether or not the oil is still "good".
I really have no idea how it could know what type of oil you used or if the oil is still functional but it would seem that way. Has anyone else noticed this as well?
Jim
The OLM uses engine revolutions, oil temperature, fuel delivery, engine load, engine speed.
There has been extensive research done by GM (i.e. Dr. Shirley Schwartz) back in the 80's to build the OLM. The OLM is tailored to each engine and driving habits, and while it does not actually look at the oil, it does constantly read the drive cycle parameters as you drive the vehicle.
The revolutions has a starting point and as you drive the current drive cycle revolutions are subtracted from the base point. While the engine is cool or in warm up, (i.e. more contaminates in oil are possible like water, or unburned fuel) there is a penalty factor applied which further subtracts at a faster rate from the base starting number.
It does not matter how many miles you drive, except as a safety factor that it will never let you exceed a pre-set amount based on engine type.
The tests done with the OLM were conducted using conventional "good" dino oil and the model doesn't care about synthetic or blended, or dino oil....
We often try to guess when we should change our oil, and this computer / sensor driven system, constantly reads inputs from sensors on motor while examining the above parameters....and when a threshold is reached then the change engine oil is tripped.
Is it perfect, no (i.e. doesn't know if you use a good oil or bad, nor does it know dusty conditions or not). But keep it
s pretty good....
    Mistycool
    Mistycool
  • Who's Online   5 Members, 0 Anonymous, 1,586 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
