Rear Cargo hinge pins on Suburban
plainvanilla
My 1997 Suburban got taged in the rear cargo doors.
I found a set off of a similar truck with the same color so I don't have to paint them
It looks like the hinge pins are a booger to get out. At least that is what they told me at the wrecking yard as we took a cut off wheel to the old hinge (body side)
Is there a good way to get these hinge pins out without tearing up the hinge?
I want to be able to hang the new doors without hurting them.
I hope someone on here has seen this in a body shop before.
thanks
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 592 Guests (See full list)
