Day time running lights
woody367
I have a 99 yukon "old body" my daytime running lights stopped working. The indicator on the dash is lit, the parking brake is off and all fuses are good. What could it be and what to check? Any help would be great. Thanks
First, check the DRL fuse in the left side of the dash fuse block. If that's okay, it could be the DRL relay, the DRL module or the DRL diode.
I checked the fuse and thats good. What should I check nest? How do I test them and where are they located? I know where the diode is under the dash just right of the gas pedal it looks like a heatsink metal right? Can I just remove that diode and put a juper in there to test? I don't know where the relay is. I looked in the fuse box under the hood and where is the module. Thanks
Yes, that sounds like the diode. Dunno if you can just jump it. Never tried that. The relay is in the "convenience" center, which is agains the firewall, to the left of the steering column. The module is under the drivers side of the dash.
Here's the diagnosis for inop DRL's. Where there are two "Go to step ..." listed below each test, you go to the first one if the answer is yes, or the second one if the answer is no. Sorry for the lousy formatting which will make this very difficult to follow, but that's the best I can do with a cut and paste. I ain't about to try to type all that out myself to make it pretty.
Did you perform the DRL System Check?
Go to Step 2
Go to Daytime Running Lights (DRL) System Check
2
Ensure that the park brake is not engaged.
Turn the ignition switch to the RUN position.
Does the brake indicator lamp light?
Go to Step 12
Go to Step 3
3
Turn the ignition switch to the LOCK position.
Disconnect the daytime running lamps (DRL) module connector.
Connect a J 34142-B test lamp from the DRL module connector, cavity C, to ground.
Does the test lamp light?
Go to Step 4
Go to Step 13
4
Connect a J 34142-B test lamp from cavity C to cavity H of the DRL module connector.
Go to Step 5
Go to Step 14
5
Remove the DRL relay from the convenience center.
Connect a J 34142-B test lamp the DRL relay, cavity G6, to ground.
Go to Step 6
Go to Step 15
6
Connect a J 34142-B test lamp from the DRL relay, cavity G4, to ground.
Go to Step 7
Go to Step 16
7
Reconnect the DRL module connector.
Does the DRL indicator lamp light?
Go to Step 8
Go to Step 17
8
Connect a J 39200 DMM from the DRL relay, cavity H6, to B+.
Measure the voltage.
Is there batery voltage?
Battery Voltage
Go to Step 9
Go to Step 18
9
Connect a fused jumper from cavity G6 to cavity H4 of the DRL relay.
Do the low beam headlights light?
Go to Step 19
Go to Step 10
10
Re-install the DRL relay.
Disconnect the headlamp connector.
Connect a J 34142-B test lamp from cavity C (base) or cavity A (quad) to ground.
Go to Step 11
Go to Step 20
11
Connect a J 39200 DMM, set on ohms, between cavity A and ground.
Is there continuity?
Go to Step 21
Go to Step 22
12
Refer to Park Brake for diagnosis.
Did you find and correct the condition?
13
Repair the open in CKT 39 (PNK) between the instrument panel (IP) fuse block and the DRL module.
Is the repair complete?
14
Repair the open in CKT 150 (BLK) between the DRL module and ground G200.
15
Inspect for an open in CKT 340 (ORN) between the IP fuse block and D203.
If an open is not found, inspect for an open in CKT 634 (YEL) between D203 and the convenience center.
If an open is not found, locate and replace diode D203.
16
Repair the open in CKT 39 (PNK) between splice S213 and the convenience center.
17
Inspect for a poor connection or damaged terminals at the DRL module connector.
Repair the DRL module connector, as necessary.
If you do not find a condition at the connector, replace the DRL module.
18
Repair the open in CKT 592 (LT GRN/BLK) between the DRL module and the convenience center.
19
Replace the DRL relay. Refer to Daytime Running Lamps (DRL) Relay Replacement
20
Repair the open in CKT 12 (TAN) between the DRL relay and left high/low beam headlamps.
21
Replace the left and/or the right high/low beam headlamp. Refer to Headlamp Replacement
22
Repair the open in CKT 150 between the left high/low beam headlamp and ground G113, and/or repair the open in CKT 250 (BLK) between the right high/low beam headlamp and ground G112.
Thanks for the info. I will try what I can this weekend. I am guessing thatafter each question answer 1 is no and 2 is yess? please correct me id I am wrong.
As I already said... where there are two "Go to step ..." listed below each test, you go to the first one if the answer is yes, or the second one if the answer is no.
I tried to figure out an easy way to post the actual, formatted page, but had no luck unless I was willing to cut and paste a whole bunch of screen captures together, which I wasn't.
I wish the forum software was better. Some allow directly pasting in images and things like that but not this one.
Thanks for the help I realy appricate it. I am having some trouble locating the relay and module. I look at the fuse box under the hood and none for DRL on the fire wall under the dash is the flasher and some other small metal relay or something. Would that be it? and as far as the module goes there is somuch stuff under th dash with the alarm that was put in I don't know what I am looking at. I went and looked at a Chiltom and Hayes manual to see if they showed it but no luck. Local people told me to look but they keep telling me to look for the system that is on the newer body style with the DRL in the markers. This is a 99 that looks like the 98 stle with the DRL as part of the headlights. Let me know of a manual or something that might show me what to look for. Once again tha you for all the help.
Bob
The DRL module is a small box taped to the harness under the left side of the dash. The relay is in the box that's against the firewall, just about where your left foot would rest while driving.
  • 4 years later...
This is what I've been looking for.
Will these steps work for a 2003 Silverado Z71?
Thanks for the help
rshelton
[quote name='GM-Tech' post='422277' date='Nov 16 2006, 03:23 PM']Yes, that sounds like the diode. Dunno if you can just jump it. Never tried that. The relay is in the "convenience" center, which is agains the firewall, to the left of the steering column. The module is under the drivers side of the dash.
Go to Step 2
2
Go to Step 12
Go to Step 3
3
Go to Step 4
Go to Step 13
4
Go to Step 5
Go to Step 14
5
Go to Step 6
Go to Step 15
6
Go to Step 7
Go to Step 16
7
Go to Step 8
Go to Step 17
8
Battery Voltage
Go to Step 9
Go to Step 18
9
Go to Step 19
Go to Step 10
10
Go to Step 11
Go to Step 20
11
Go to Step 21
Go to Step 22
12
13
14
15
16
17
18
19
20
21
22
Is the repair complete?[/quote]
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
