Xmas Navigation present help!
howufiga
Ok, so my girlfriend bought a 2006 Trailblazer EXT. It hs the overhead DVD player in the back and a double din Bose stereo. The only thing she desperately wanted was the navigation. Now I looked at some of the posts and I need some clarification.
I looked in my glovebox and the number did not have the Y91 on it. So is this a non-lux stereo? what are the Navigation Unit model numbers I should look for?
Do I need a wiring harness to make the Navigation work?
Does the Navigation Unit have an antenna? If it does, where is it located? What else does the navigation unit need?
Does the navigation unit use DVD for navigation? If it does, what disc changers can I use with the navigation unit and what is the model number?
Think that's about it. I hope I can surprise her with it before Xmas if I can find all the parts. Thanks!
if you don't want to look around for parts, give jp customs a call. they have a package for trailblazer with nav unit, antenna, map disc, cd changer (extra), splice items, and instructions. if you want it before x-mas, this may cost more but may be the way to go.
http://www.jpcustoms.com/store/customer/pr...&cat=359&page=1
In the auction, it says "FOR $100 EXTRA WE CAN PROGRAM THE RADIO SO THAT ITS PLUG AND PLAY NO DEALER NEEDED". What do they mean by that? is that something i can do by myself?
Once a radio is installed in a vehicle the radio "learns" the VIN of that particular vehicle. If the radio is removed and placed in another vehicle, it will not work because of the Anti-Theft feature. The "programming" consists of connecting the dealer's Tech 2 handheld unit to the vehicle and clearing the VIN from the radio so that it will work in the new vehicle. My dealer did this for me for free. You cannot do it on your own since you need the Tech 2 unit.
will all dealers do this for free?  If not, how much would it typically cost for them to clear the VIN?
It only takes them 5 minutes. I have a good relationship with my dealer and service dept. so they didn't charge me. I can't tell you how much your dealer might charge you, maybe 30 mins. labor, maybe nothing.
I gotta say them charging 100 bucks to clear the VIN is just robbery. IMHO you should buy an Ebay package and hit the nearest dealer. My bet is they'll charge you half that if anything at all.
well, we'll bring it to the dealership she bought the truck from. Maybe they'll do her a favor.
I forgot that it has the factory installed Panasonic rear DVD player. Will this work with the new stereo? I'm looking at GM Part #15800000.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
