Memory Personilization Issues
I've got a 2003 Yukon and I'm having some issues with the memory seats. I have 2 FOB's but I'm the only driver so I don't use the 2nd one. I'm having a problem with my memory Seats.
The seat was working perfectly, returning exactly to its position when entering, and the exit function is turned on when I remove the key. It seems for no reason at all and all of a sudden they don't work anymore, mainly the exit function. My seat used to go back fully and down some when exiting. Now it moves a few inches back, sometimes forward! Even when I press the exit button. Is there a way to reset the personification memory features? I dont know how or where to start to fix this problem. Ay help would be appreciated. Thanks.
Bryan
I believe you can try to save the exit settting just like you would save the memory seating position for driver 1 and 2... just position the seat where you want to to be during exit, and hold down the exit button for a few seconds until it beeps.
If that doesn't work, I don't know what to tell you... :rolleyes:
Exactly right. I guess I moved my seat a small amount and accidentally held the exit button instead of the correct driver button. Thanks.
Bryan
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
