I have a set of front and back dee zee mud flaps powder coated black for sale.
The part numbers are:
Front - Deezee #1808
Rear - Deezee # 1800
I had them powder coated with a semi gloss black because i coundnt find black ones anywhere.
I decided against putting them on (even though they look AWSOME), i am going to put on paint matched fender flares instead.
I bought the mud flaps for 55 and then paid 45 to have all 4 powder coated.
All i want is to recover my money out of the deal.
I am asking $100.00 plus shipping to where ever you live. (i will only charge actual shipping cost)
I will get pics and post them soon.
If someone has fender flares that are in good shape and that would fit a 99-02 silverado 1500 i would consider a trade or make a deal.
i really like how those look, and they'd match my toolbox, but i dont want to stop mud from gettin on my truck when i go tmudding :D
Thats hilarious that you want to KEEP getting mud on your truck lol.
Then what you do when you put them on is dont let them stick out to far and mud still gets everywhere...trust me on this one i did it o my last truck.
<{POST_SNAPBACK}>
yeah gotta display my warpaint
well if i win the lottery ill get to you on buying these, a hundred dollar bill is the last thing i have sitting around now with no use......try them on ebay, im sure they'll go fast
