exhausts
Borla makes some nice stuff (stainle$$).  I see thay have the 8.1L crewcab listed, so I bet it would work with the 6.0L if that's the motor you have...
It is a split side exit and the part numbers are 14959 or 14959F  (I'm not sure what the difference is between the two).  The price on Borlas' site is $739, but you could probably do better shopping around on the net.  They are expensive but I really like the one I put on my truck 2 trucks ago, plus they have a great warranty and the muffler won't burn-out.
  • 1 month later...
Gibson has two systems available for the 6.0 and only one available for the 8.1.
You can put an 8.1's exhaust on a 6.0, but not the other way around.  The stock system on the 8.1's is already a 3.5" system STOCK!
