Side rear window adjustment?
Motorand
I have a 2002 Silverado extended cab and the back passenger window leaks air at highway speeds, you can pull on it and stop the leak. Is there a way to adjust the window mechanism to tighten it up?
Thanks!
Here's how we fix 'em. First, you need a heat gun. I doubt a hair blow dryer will not get hot enough, you'll need a real live heatgun.
Remove the trim from the door (to prevent damaging it with the heating procedure) and disconnect the latch from the 1/4 window frame. What you're left with is a plastic arm sticking out that's part of the window frame. This piece is what the latch was hooked to.
Heat up this plastic arm and bend it in slightly and hold in place until it cools a bit. This causes the latch to pull the window tighter into the weatherstrip. Put it all back together and you're done.
There's another method of drilling holes through the door frame and into the plastic and installing screws to pull the whole assembly in. I think there might even be a TSB on this, but I'll have to look. I think we use the heat method that we came up with because the screw method didn't always work.
Here's a TSB I found that I had not seen before. Perhaps this replaced the TSB on using screws because I couldn't find that one. In any case, this MIGHT be easier for you to do since it doesn't require a heat gun, only some pliers. Having never performed this procedure, I don't know any more than what it says here. Sorry that the pictures don't copy/paste when I copy these...
Subject: Wind Noise from 1/4 Glass - keywords adjust air driver latch leak left passenger right water #PIT3787 - (11/28/2005)
Models: 2003-2006 Chevrolet Silverado
2003-2006 GMC Sierra
Extended Cab Models Only
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Owners may comment on a wind noise coming from the rear 1/4 glass of their extended cab truck. The wind noise may be diminished by pulling in on the glass handle. This concern may be caused by the glass handle/latch not holding the 1/4 glass closed tight enough against the weather seal. In most cases, the 1/4 glass will not be flush with the body/door and will be sticking out a few millimeters.
Recommendation/Instructions:
To correct this concern, adjust the 1/4 glass mounting flange inward so the handle/latch will pull the 1/4 glass tighter to the weather seal. Use the following procedure to adjust the mounting flange inward:
Remove the Side Access Door Trim Panel per SI Document ID # 764454.
Open the 1/4 glass to the full open position.
Use channel locks or equivalent pliers and a cloth to adjust the mounting flange inward. Use the cloth to protect the painted surface of the flange and the 1/4 glass plastic frame and weather seal.
With the cloth in the jaws of the pliers, adjust the flange inward below the 1/4 glass handle/latch.
With the cloth in the jaws of the pliers, adjust the flange inward above the 1/4 glass handle/latch.
Note: It may take some pressure to adjust the flange inward. If a good thick cloth is used, no damage will be done to the painted surface or 1/4 glass frame/weather seal.
After adjusting the flange, close the 1/4 glass and check glass flushness to the body/door. The glass should be flush or slightly inward from the body/door, if not repeat steps 4 and 5.
Reinstall the Side Access Door Trim Panel per SI Document ID # 764454.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
WOW!!!
You guys are impressive! Thanks :banghead:
    • Rise more slowly?  Debatable.  It would run slightly cooler, yes if anything after adding the thermostat delete kit from PPE.   PPE makes a larger front aux cooler which they "claim" will lower temps 45 degrees but I have not used it.     IMO, especially in cold states, I would not want to mess with the first cooler, the oil to water one.  Cold states, you want heat in the transmission for it to shift properly, and you don't want moisture in the ATF.    Ideal temps for automatic transmissions to do their job the best is 175-220F.  Hotter than 220F you start heading towards fluid degradation and shortened fluid life/service intervals.  240F can start varnishing things like the fluid, clutches, etc.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
