Temp Gauge
martys55
Hopefully someone will know this answer...
I have a '93 GMC Sierra with a 4.3 V6. The other day I noticed the temp gauge wasn't working (all other gauges were) so I changed the sending unit thinking I had it fixed. Well that didn't fix it so I looked again at fuzes hoping I had simply missed it. I saw a gauge fuse and pulled it out. Now here's the strange thing...the temp gauge looked like it started working, but all the gauges quit! I put the fuse back in and all the gauges worked except for the temp gauge.
Any ideas? I really would like to get this fixed as the engine started knocking once it weas warmed up. I need to figure out if the knock is associated with an overheating problem.
Thanks for ANY help,
Marty
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
