2005 Hummer 2, Nav help!
I am trying to install a lux radio in my brothers H2, i verified in the glove box, that the Y91 option is from factory. The lux radio is #15204334, would i need to upgrade the amp to a lux amp, or is it just a plug and play install?
Need some advice in installing?
Thank You
Alctrztz
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 239 Guests (See full list)
