FUEL GAUGE NEEDLE
PA.MOUNTAINMAN
The needle on my '98 started doing that a few months before the sending unit on the in-tank pump/pickup went bad.
Don't know for sure if this applies to the newer trucks, but in the older ones, the gauges used a damping mechanism, which I believe was a viscous fluid, that would dampen needle movement. This would prevent the needle from moving quickly with every little change. When this damping mechanism failed (leaked out?), the needle would do what you described.
The fix was to replace the gauge, which were separate components back then. If this is what's wrong with yours, and I'm not sure it is, the cluster would need to be sent out for repairs.
Thanks for you response.If there is no harm in running it that way I think that is what I will do....
