Need Help slipping in wet weather
Hey have an 07 classic witht he 4.3 and thats about it.
In the rain and heavey mud the car spins its rear tires like crazy. Its 2wd becuase well i like sliding alot, and well yeah.
Anyways i was wondering is there like a diff I can put in the rear end to help with this. IF so what kind if somone has a link that would be awesome.
Anything else to help in the mud let me know thanks!!
OH yeah I know more weight in the back but its already loaded dowin with tools and tile.
You could put in a locker and get some better tires. Throw some weight in the back end (500 lbs of sand would help). Otherwise, not much you can do to make a 2wd stop spinning.
What are your stock tires? My stock Firestone Wilderness LE's were horrible in the wet and would spin when lightly accelerating from a stop. HUGE difference when I switched to Michelin LTX M/S. A locker would help too.
I would recommend putting in a limited slip, then just setting the clutches tight if you want the locker type action without spending that much money.
i would think the cheapest route is to find a used G80 since those come factory. Try Ebay, etc
where can i find a locker, for the life of me i cannot find one online??  Somone know the name or a store that sells one?
If you can find an entire rear axle with your gear ratio/brake setup and a G80 in it at a junk yard, then just buy and install that. Simpler, faster, and usually the same price/cheaper.
just so you know, a locker usually isnt desired when driving in the snow and ice.
You sure about that? I sure would rather have a locker than a posi in the snow and ice.
:banghead:
Have you driven in snow? Why wouldn't you want a locker?
Putting in a locker with the same tires is the worst thing you could possibly do.
My truck came stock with the locker and s**tty ass goodyear tires. There was no such thing as one wheel slippage, if I lost traction with one wheel, the locker would just break the other loose and send the back end flopping around like a wet rag...
Put on some better tires. I went with Bridgestone Dueler H/L Alenzas. Not only is the traction difference unbelievable, but the f**kin thing handles 10x better now.
