XM Roady XT Install on a 2000 Blazer
cmoore74
Hi All,
Picked up an XM roady xt for the wifes 2000 blazer. I was hoping that someone out there could answer a few questions:
I plan on picking up the FM direct adapter to plug the XM reciever directly into the FM antenna. Do I have to pull the dash and radio to access the antenna wires in the back?
Is there a better alternative to the FM direct adapter? Not sure if there are any RCA input on the back of the factory radio.
Any pieces of advice on overall installation?
Thanks,
Chris
i used one of the direct adapters in my 1997...works alot better than just using the FM modulator...your still using the the fm modulator but it works way better
u will have to pull the stereo to install it
After some more searching I came across XMFan.com. They had all of the answers to my questions.
BTW the radio in the blazer has an unused Aux input so I think I'm going to get one of the Aux adapters and hook it in through there.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
