Speakers don't work when it rains
48fan
I have a 99 Silverado and when it rains or when I take it through the car wash the speakers stop working. When they stop working and I'm in the truck to hear them stop working they fizzle or crackle out kinda like bad reception on a radio. In other words it does't just shut off. The display on the radio works fine, it shows the radio station correctly, it switches to CD and Tape correctly and it shuffles through tracks as well. When the sound does comeback and I'm in the truck it usually fades in just like they fizzled or crackled out. When I start up the truck and everything has already dried the sound is blasting.
Obviously the water is causing a short but where it is I do not know. The rubber boots in the door jams are still intact and are protecting the wires fine. I don't know where the amp is so it's possible it could be the amp but that would mean I have a leak somewhere. The other possibility is the ANT wire or the ANT itself.
Has anyone ever had this happen or have an idea of what it could be?
Thanks,
Mike
could be a short at the back of the speakers since they are exposed to the water coming off the window. If you know how you could pull the door panel and see
Sounds like it is water getting in the door and shorting the speakers right out . their is something you can get that can protect them from shorting out again. I have seen this rubber baffel that will go behind the speaker houseing where it mounts and can make it water proof. i seen them somewhere but forgot where.
Crutchfield has them. I put them on my new type-R's because i cant stand the thought of getting my bran new $400 speakers wet
