running boards,step rails or nerf bars
OK this is my first full size PU and the wife is beaching about getting in and out
She is 4'11"
What do you guys recommend, running boards,step rails or nerf bars. Fuction is the
key here looks are second. What brand, how much and best place to buy....
Thanks :confused::cheers:
I too have a very short wife and have never owned a 4x4 that didn't have a set of nerf bars or running boards. Personally, I have been using Nerf Bars for the last 8 years and they are functional yet look better than running boards. I've always bought the GM brand from the dealer after doing a little negotiation and begging with the parts guy. They usually come down 20% and it makes it cheaper than anything else I can find...installation is a breeze and the wife loves them. She ALWAYS uses them and doesn't have to worry about snow/ice making them slippery.
Gotta love those little gals!
Here is a link to a recent discussion in the ":How To" forum that might help you a little:
Nerf Bar Discussion
You can also do a search and find TONS of information that has already been discussed.
Good luck!! :confused:
I had running boards on mid and late 80's Full Size Jimmys. My wife is also short. Since my last Jimmy I started using the nerf bars for 2 reasons. 1) The running boards tend to hold dirt and debris against the body. Both Jimmys had to have the rocker pannels replaced because of rust. Note there was no rust anywhere else on either vehicle. 2) Nerf bars eliminate this problem and IMHO look much better.
I have nerf bars and wish I had running boards as the slush builds up between the bars and the body of the pickup.
I will be honest I have no clue what is a step bar or nerf bar. But from my signature with picture you can see what I do have on my truck. I have had running boards on previous vehicles but have come to enjoy the kind of bars I have now much better.
The one thing my wife was concerned about was her foot slipping threw. After talking with the guy who installed them for us and checking out some on vehicles she was convinced they were fine. She has had no problems with them, also she is 5' and I stand 6'3".
My vote is the bars, but also make sure you include your wife as she needs to be comfortable using them as well.
Have a nice day.
Bill
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
