The console lid issue
every one that has the base style console pictured in this post has probley noticed that the lids some times break alot of these have this problem. So i have put together some of the part numbers excuding avalanch and some tahoes and yukons. Since ive ran into this countless times here in the parts dept. ive also notice that gm partech has been saying that there is a design change so wanted to give you guys a head start on getting these things.
for pewter (x88) ;chevy use 88941272
that works for : (03,53,43) cab styles,....reg,ex,crew
for neutral (x88) use 88941274
same as above applies
for pewter (z88) 88941268
03,53,43 and as well as some yukons
for neutral (z88) 88941270
03,53,43 and some yukons
all of these consoles are compleate units they have to be purchased by the whole not service in detail.
but gm says the mounting holes are missing threads so they want self tappers [12474220]
any way just wanted to let you all know these numbers cus your dealer might have a hell of a time finding them.............like i did...lol
Heres a bulletin on just the lid....
Document ID# 1851484
Subject: Front Seat Armrest Hinge Breaking (Replace Lid) #06-08-50-004A - (07/28/2006)
Models: 2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2006 GMC Sierra, Yukon, Yukon XL
with Front Split Seat (RPO AE7)
This bulletin is being revised to include RPO Code and interior trim color code information. Please discard Corporate Bulletin Number 06-08-50-004 (Section 08 -- Body and Accessories).
DO THIS
DON'T DO THIS
Replace just the lid for the armrest.
Do NOT replace the armrest assembly.
Condition
Some customers may comment that the lid for the armrest is broken.
Correction
Replace the armrest lid using the procedure below.
Open the armrest lid.
Remove the armrest inner panel. Use a flat-bladed screwdriver and place it between the two panels and pull to separate.
Fold the seat backs to gain access to the hinge pin. Using a punch, push the hinge pin out.
Install the two springs into the new armrest lid.
Align the two springs and the lid to the armrest and install the pin.
Install the inner lid to the armrest and close the lid.
Place the seat back in the upright position.
Parts Information
Part Number
Description
19127364
Compartment Kit, F/Seat Stor (Dark Pewter) (69I)
19127365
Compartment Kit, F/Seat Stor (Pewter) (92I)
19127366
Compartment Kit, F/Seat Stor (Neutral) (52I)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
C2740
Door And/Or Pad, Console Compartment - R&R Or Replace
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
I've replaced my whole console once and I need to do it again. do I need to replace the whole thing? according to the bullitain I can replace just the lid? Can I order just the lid?
Last time it cost me $200. I hope I can find another way. I have grey cloth interior.
