ALLI!!!!
had top take ruck to dealer yesterday. trans would not #### or move the truck. took it in they cranked up the pressure and and reset it runs ok now.. they dont have any idea what happend. kinda shakes and shimmys and barley moves. fluid level fine. they said there was not any codes or anything..!!! so i guess i will have to deal with it for now. anyone else having this problem or has had this problem! :bored:
well that really suxs!!! i need to trade it in i guess. this aint good because this is my first gm product and man 6000 miles later im having problems. dont get me wrong all of them do but not this early in the game.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
