4.56 gears installed abs issues
I recently bought an 06 short crew and installed a 6" lift with 35's. We installed some 4.56 yukons and now my ABS is not fuctioning correctly. We hooked it up to the tech 2 and changed the tire size around got it to work with in town driving, but when I get on the highway it still thows a code for wheel speed variance. I know this is a problem but was just wondering what my options were, any thing helps. Thanks Jerry
easiest way would be to figure the gearing into the tire size.
i had the same issue, i bought the hypertech unit, and programmed tire size and gears, but hypertech told me after that there software doesnt get into the abs system. so my speedo is correct but after i drive the truck for about ten minutes my abs light goes on, jet claims to fix the abs problem but i don't have 300 bucks to buy another programmer. let me know if u find any thing else that works.
http://www.jetchip.com/products.asp?pid=21381
I have the superchips programming and it's an option when programming to choose the new gear size.
I know many members have the westers programming so they would be better able to help you out in that department.
  • 4 months later...
I have a 2007 Silverado classic 1500. I bought the JET programmer and it did not work at first. I have 4.56 and 35.60 inch tires. (315/70/17) When i first programmed it for the correct tire size and gear ratio the ABS light still came on. I took a trip and checked my speedometer on the highway signs and noticed it was off. So i took my GPS and played around with the JET. When the JET was set to 33.5 and the gears at 4.56 this fixed the porblem. Now my speedometer is spot on and the ABS light is not a problem anymore. Hope this helps. jon66mann
LS1 Edit software, screw handheld programmers.
And as much as I seem to just find the bad things in everything, good luck with those yukons. Ive had nothing but problems with them in the past. They are poor quality and they alway seem to whine........ Motive gear is the way to go...
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
