No floor drain in garage. Ideas?
jjrobo
I recently bought my first house and it has a detatched 3 stall garage. It is built on a slab and doesn't have any floor drains. Worse yet, it all drains to the back. Now that it is winter, it is getting to be a real mess.
Does anybody have any ideas on a way to get some floor drains in there for next winter? I am thinking of renting a concrete saw and installing some myself. This is my last resort so please give me some ideas.
I have a wood funrnace that I hope to install when I get the chance. I think that will help a little with keeping things dry. But it doesn't look like that is going to happen this winter.
Thanks,
Jeff
Your garage may not have been built to code. All detatched garages are usually built with a slight slope to the slab to drain to the street or the general direction. If it is older the garage might have sunk a bit. So to correct this you can have the back end of the garage sand jacked or mud jacked to the proper grade which will aid in drainage. If you bought this house from a previous owner who built this garage you may be able to make them pay for repairs depending upon your laws, and if the city code was in violation before you purchased the house.
It is about 15 years old. It was built to code, assuming it did settle in the back. I could tell it was going to be a problem when I first looked at the house. I'm now looking for a solution and I wouldn't even think of making the previous owners pay for it.
Why is there an advertisement in the middle of my previous post?
Jeff, I can feel for you I have the same problem in my garage. My garage is heated with a natural gas furnace but prices of natural gas prohibits it's regular use.
Your floor has a level elevation apparently to the back so putting drain holes in under the cars won't help much. The concrete needs reshaped like a sink to allow the drains to work correctly. The easiest thing to do is put in a trench style drain along the back with a grate over top to collect the water.
Sort of like this.
Cause someone thought we needed more spam in our lives :)
cut a hole through that back wall at floor level, and put a house style air grill in it with wire mesh behind.
Jack up your garage from under the concrete and pour a pier under it, thus re-leveling the garage. Or saw cut a trench in the back place a trench drain, like the ones in a previous picture......but they have to be piped out your garage into a storm drain, you could sink one into the side of your garage and have the drain water dump into it. Just a few suggestions. Or bust up the current floor ad re-pour.
I think you need a very attractive woman to stand in the garage with a mop. Of course, she should be wearing a bikini while on the job, but that is just me.
Best of luck with THAT idea, especially if you are married! :cheers:
Well, I guess it wouldn't hurt to add another smart a$$ suggestion.....
Just move the garage doors to the side that the water drains to. In which case the front will be the back and the back will be the front.
Problem solved. :cheers:
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
