www.truckstuffonline.com
FergieDSP
Check these guys out. They don't have everything, but still a good selection. They have decent prices, fast shipping and also free shipping. I bought my Westin Ultimate Bull Bar from them and got it for a cheaper price than I found other places, plus shipping was free. I received the item in 3 days.
  • 2 months later...
On fullsize trucks, yeah they mount into where the tow hooks go. On my Colorado it was mounted to the frame under the bumper via brackets but it still blocked the how hooks. That's why I don't really like them unless you don't go offroad that much. Worse comes to worse though, you can still be pulled out by your ball.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
