Please Help With A/C Issue
2001 GMC 2500HD SLT 8.1/Ally
Whenever the A/C air flow control is selected to recirculate (button is latched on) the A/C compressor runs, regardless of whether the A/C is commanded on or not. The only way to shut off the compressor is to select fresh air.
Other owners tell me their trucks don't do this.
Anyone experience this problem or can help direct me towards a fix?
Thanks in advance!!
theyre wrong. all of them 99-06 run the compressor with recirc on. Just like if you put it on defrost, the compressor runs.
x2
DEWFPO
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
