Install differential actuator
97silver1500
I am installing a new differential actuator, and they say to run the brown wire to the transfer case and I cannot seem to figure out where it connect to. Please help me if you know where to find a diagram for this procedure, it is not in my manual.
Sounds like you are retrofitting the newer style stepper motor type actuater in place of the original thermal type actuater. If so, you need a wiring harness that your dealer should have sold you with it. It has a wiring diagram and instructions for the retrofit. Easy job, I did it under a truck stuck in a ditch in a snowstorm, 1/2 hour.
