Squeaky Belt
A guy that I work with has a Alli/Max 2001 CC truck, he has been having problems with his belt squeaking. It has squeaked for about 1 year, he has brought it back to the dealer and they replaced the tensoner and the belt. The sound cam back a month later. He has since replaced the belt multiple times. Has anybody else had a similar probelm, and what was done to resolve it. The delear now claims that it is not a problem.
Thanks
2001 Sierra 2500HD 4x4 Reg Cab 8.1 6spd 4.10
Ultimate Spray On Bed Liner,
Ranch Hand HD ROVER Front Replacement
Is it squeaking all the time, or just when he shuts the motor off?  If it is just when shutting the motor off, that is normal to all diesel engines (just can't hear it on most of them).  Because of the high compression ratios the motor stops turning very quickly, and causes the belt to squeak a bit.  I doubt you will ever be able to get rid of that.  If it is all the time, I can't be of any help.
If it's squeeking all the time, it could be a pulley on another accessory.  Of course, that newer tensioner may be shot too!!
I had the same problem.  Squeaked all the time.  The grooved idler pully (left side on engine) under the belt tensioner pully was the problem.  The sealed bearing was bad.  He can test this.  Take the belt off and spin the pully.  If it spins one, maybe 2 times, it it good.  If it spins alot (really free) then its bad.  The sealed bearing work this way in the pully.  It cost me $26 bucks for a new pully and all is well now.  Only a squeak at shutdown.  I am going on 70,000 miles on my D-max.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
