Stop Guessing
I've seen alot of guys talking about a new Campaign that is out now.
Here it is.
Take your truck in for service if it falls within the VIN breakpoints.
http://service.gm.com/servlets/BlobShtml?S...amp;evc=numSrch
And I saw a fellow ask if this Campaign would fix the fuel gage on his '00 Silverado.
Nope, but a new sending unit would fix it.
Enjoy.
Oh, I've personally done about 9 of these re-programs.
...maybe we can get somebody to copy that page??
Look for document id# 1904142
Heres document ID#1904142,Hopefully its what your after....
Document ID# 1904142
Subject: Service Update for Inventory and Customer Vehicles-Remote Keyless Entry (RKE) Inoperative and Battery Rundown-Expires with Base Warranty #07007B - (02/13/2007)
Models: 2006 -2007 Buick Lucerne
2006-2007 Cadillac DTS
2007 Cadillac Escalade, Escalade ESV, Escalade EXT, SRX
2006-2007 Chevrolet Impala, Monte Carlo
2007 Chevrolet Avalanche, Equinox, Suburban, Tahoe
2007 GMC Yukon, Yukon XL
2007 Pontiac Torrent
CERTAIN 2007 CADILLAC SRX VEHICLES HAVE BEEN ADDED TO THIS SERVICE UPDATE.
DISCARD ALL COPIES OF BULLETIN 07007A, ISSUED FEBRUARY 2007.
TECHNICIAN MAY EXPERIENCE SLOW PERFORMANCE USING THE TIS2 WEB APPLICATION WHEN REPROGRAMMING THE VEHICLE TO CORRECT THE CONDITION. TECHNICIANS MAY NOTICE THE SLOWER APPLICATION PERFORMANCE FROM MID-MORNING UNTIL LATE AFTERNOON.
TO ASSIST IN IMPROVING PERFORMANCE AND REDUCE PROGRAMMING TIME, IT IS RECOMMENDED TO COMPLETE THE BULLETIN PROCEDURE ON CUSTOMER VEHICLES FIRST. VEHICLES IN INVENTORY SHOULD BE PROGRAMMED DURING OFF PEAK HOURS IF SLOW PERFORMANCE IS EXPERIENCED.
Purpose
This bulletin provides a service procedure for reprogramming the remote control door lock receiver (RCDLR) and the remote keyless entry transmitter (FOB) on certain 2006-2007 Buick Lucerne; 2006-2007 Cadillac DTS; 2007 Cadillac Escalade, Escalade ESV, Escalade EXT, SRX; 2006-2007 Chevrolet Impala, Monte Carlo; 2007 Chevrolet Avalanche, Equinox, Suburban, Tahoe; 2007 GMC Yukon, Yukon XL; and 2007 Pontiac Torrent vehicles. On these vehicles, the RKE may become inoperative.
Also, for the 2007 Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Suburban, Tahoe; and GMC Yukon, Yukon XL vehicles (GMT900 Utility) only, this bulletin provides a service procedure for reprogramming the body control module (BCM). On these vehicles, and under certain conditions such as operating the radio with the engine off, the battery can become discharged, preventing engine start-up.
This service procedure should be completed as soon as possible on involved vehicles currently in dealer inventory and customer vehicles that return to the dealer for any type of service during the New Vehicle Limited Warranty coverage period.
Vehicles Involved
A list of involved vehicles currently in dealer inventory is attached to the Administrative Message (US) or Dealer Communication (Canada) used to release this bulletin. Customer vehicles that return for service, for any reason, and are still covered under the vehicle's base warranty, and are within the VIN breakpoints provided below, should be checked for vehicle eligibility in the appropriate system listed below.
Year
Division
Model
From
Through
2006
Buick
Lucerne
6U239124
6U257638
2007
Buick
Lucerne
7U100037
7U145583
2006
Cadillac
DTS
6U242236
6U550983
2007
Cadillac
DTS
7U100035
7U550290
2007
Cadillac
Escalade
7R205610
7R297216
2007
Cadillac
Escalade ESV
7R205602
7R297219
2007
Cadillac
Escalade EXT
7G125584
7G216104
2007
Cadillac
SRX
70105538
70105538
2007
Chevrolet
Avalanche
7G115332
7G219134
2007
Chevrolet
Equinox
76000122
76049192
2006
Chevrolet
Impala
69415117
69438808
2007
Chevrolet
Impala
79100039
79205077
2006
Chevrolet
Monte Carlo
69418495
69438794
2007
Chevrolet
Monte Carlo
79100031
79205067
2007
Chevrolet
Suburban
7G115874
7G216179
7J177460
7J271439
7R205596
7R291737
2007
Chevrolet
Tahoe
7J177482
7J270240
7R205597
7R297218
2007
GMC
Yukon
7J170054
7J270257
7R205595
7R297177
2007
GMC
Yukon XL
7J176046
7J271436
7R205599
7R296525
2007
Pontiac
Torrent
76000125
76048906
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using GMVIS. Not all vehicles within the above breakpoints may be involved.
Service Procedure
Important: Technicians may experience slow performance using the TIS2 web application when reprogramming the vehicle to correct the condition. Technicans may notice the slower application performance from mid-morning until late afternoon.
To assist in improving performance and reduce programming time, it is recommended to complete the bulletin procedure on customer vehicles first. Vehicles in inventory should be programmed during off peak hours if slow performance is experienced.
Important: This bulletin contains two reprogramming procedures, 1) reprogramming of the BCM, and 2) reprogramming of the RCDLR. Not all vehicles require reprogramming of both.
• The Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Suburban, Tahoe; and GMC Yukon and Yukon XL vehicles require the BCM and RCDLR reprogramming.
• The Buick Lucerne; Cadillac DTS; Chevrolet Impala, Monte Carlo; Chevrolet Equinox; and Pontiac Torrent require only the RCDLR reprogramming - DO NOT ATTEMPT TO REPROGRAM THE BCM ON THESE VEHICLES.
Body Control Module Reprogramming - For Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Suburban, Tahoe; and GMC Yukon, Yukon XL ONLY:
Important: The calibration numbers required for this service procedure are programmed into control modules via a Techline Tech 2® scan tool and the Techline Information System (TIS) terminal with the calibration update. Use TIS 2 Web version 2.0 for 2007 (available on 02/04/07) and on TIS DVD version 2.0/2007 or later, that was mailed to dealers on 02/14/2007. If you cannot access the calibration, call the Techline Customer Support Center at 1-800-828-xxxx (English) or 1-800-503-xxxx (French) and it will be provided.
Notice: Before reprogramming, please check the battery condition to prevent a reprogramming error of any of the modules due to battery discharge. Battery voltage must be between 12 and 16 volts during reprogramming. If the vehicle battery is not fully charged, use jumper cables from an additional battery. Be sure to turn off or disable any system that may put a load on the battery, such as automatic headlamps, daytime running lights, interior lights, heating, ventilation, and air conditioning (HVAC) system, radio, engine cooling fan, etc. A programming failure or control module damage may occur if battery voltage guidelines are not observed.
The ignition switch must be in the proper position. The Tech 2® prompts you to turn ON the ignition, with the engine OFF. DO NOT change the position of the ignition switch during the programming procedure, unless instructed to do so.
Make certain all tool connections are secure, including the following components and circuits:
• The RS-232 communication cable port
• The connection at the data link connector (DLC)
• The voltage supply circuits
DO NOT disturb the tool harnesses while programming. If an interruption occurs during the programming procedure, programming failure or control module damage may occur.
DO NOT turn OFF the ignition if the programming procedure is interrupted or unsuccessful. Ensure that all control module and DLC connections are secure and the TIS terminal operating software is up to date.
Tech 2 Pass-Thru Method for the Body Control Module (BCM)
Verify that there is a battery charge of 12 to 16 volts. The battery must be able to maintain a charge during programming. Use an additional jump battery if necessary.
• If the vehicle will not start, test and charge the battery. Refer to SI for battery testing and charging information, if required.
• If the battery will not hold a charge, replace the battery. Do NOT replace the battery unless it can’t be charged or a leak and/or physical damage is present.
Connect the Tech 2 to the vehicle and the TIS terminal.
Turn the ignition to the ON position with the engine OFF.
After all warning chimes inside the vehicle have stopped, turn on the Tech 2.
On the TIS terminal go into SPS Programming.
Select Pass Thru programming.
Follow instruction on the TIS terminal. When you get to the Supported Controllers screen.
7.1. Scroll down in the top box and select BCM (Body Control Module).
7.2. In the lower box select Normal.
7.3. Select Next.
Select NEXT when the calibrations screen displays.
Follow on-screen prompts until programming is completed.
When programming is complete.
10.1. Turn off Tech 2.
10.2. Turn the ignition switch to the OFF position.
Wait 30 seconds.
Turn the ignition switch to the ON position with engine OFF.
Turn on the Tech 2.
Go into diagnostics and check for DTC codes.
Clear all codes.
Proceed to RCDLR Reprogramming.
RCDLR Reprogramming - For All Vehicles
Important: The Tech 2 diagnostic tool must be updated with version 27.003 or later for reprogramming the Remote Control Door Lock Receiver (RCDLR).
The calibration numbers required for this service procedure are programmed into control modules via a Techline Tech 2® scan tool and the Techline Information System (TIS) terminal with the calibration update. Use TIS 2 Web version 10 for 2006 (available on 10/01/06) and on TIS DVD version 10/2006 or later, that was mailed to dealers on October 18, 2006. If you cannot access the calibration, call the Techline Customer Support Center at 1-800-828-xxxx (English) or 1-800-503-xxxx (French) and it will be provided.
Tech 2 Pass-Thru Method for Remote Control Door Lock Receiver (RCDLR)
Important: The Copy and Paste procedure in Step 7 does not apply to 2006 Lucerne vehicles. Please refer to the appropriate Tire Pressure Monitor reset procedure in SI.
Turn on the Tech 2.
Build the vehicle using the Tech 2.
Using the Tech 2, navigate to Vehicle Control Systems / Module ID Information / Remote Control Door Lock Receiver / Tire Information.
Write down all four Pressure Sensor IDs on a sheet of paper.
Using the Tech 2, navigate to Vehicle Control Systems / Module Setup / Remote Control Door Lock Receiver.
Important: If "Replace Module Per Service Manual" message appears on the Tech 2 during this procedure, ignore the message and press the "Exit" key on the Tech 2 and proceed to the next step. Do NOT replace the module.
Run the Copy and Paste TPM Information Procedure (F0: Step 1). Follow the on-screen instructions: Turn the ignition to the ON position with the engine OFF.
Turn off the Tech 2.
Turn on the Tech 2.
Follow instruction on the TIS terminal. When you get to the Supported Controllers screen:
13.1. Scroll down in the top box and select RCDLR (Remote Control Door Lock Receiver).
13.2. In the lower box select Normal.
13.3. Select Next.
Important: Some vehicles will require additional selections in the module field before you can proceed and the "Next" button is functional.
When the Calibration Screen displays, select calibration 25808841 for vehicles that are NOT equipped with the remote start feature or calibration 25808842 for vehicles that are equipped with the remote start feature. After selecting a calibration, select Next.
Follow the on-screen prompts until programming is completed.
When programming is complete:
16.1. Turn off Tech 2.
16.2. Turn the ignition switch to the OFF position.
Wait 30 seconds.
Turn on the Tech 2.
Run the Copy and Paste TPM Information Procedure (F1: Step 2).
Verify that the four Pressure Sensor IDs match those that were recorded in Step 5.
Clear all codes.
Programming Remote Keyless Entry Transmitters (Vehicles in Inventory)
Important: All of the transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. Once the Invalidate All Fobs selection is made or the RCDLR module has been reprogrammed, all learned transmitters are erased. Up to 8 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Program remote keyless entry transmitters.
With a scan tool, access the Remote Control Door Lock Receiver Module Setup menu. Select Program Key Fobs.
Select Next Available Slot. Follow the on-screen instructions. Simultaneously hold the LOCK and UNLOCK buttons on the keyless entry transmitter to program.
When all the desired transmitters have been programmed, exit the vehicle and operate the transmitter functions in order to verify correct system operation.
Programming Remote Keyless Entry Transmitters (Sold Vehicles)
Important: Make several copies of the programming instructions found on the last page of this bulletin, if required.
Some customers may not bring all of their remote keyless entry transmitters to your dealership for programming. Vehicles are sold with two transmitters. However, customers have the option to purchase additional transmitters. Ensure that customers understand that all of the transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed at one time in order to function properly. Program the transmitters that the customer provides to you using a scan tool. Inform the customer that all of the remaining transmitters will not function properly until they are programmed. Customers must program all of their transmitters, including the transmitters programmed at your dealership , at one time, using the driver information center (DIC) programming method. Inform customers to locate and program their transmitters using the procedure provided on the last page of this bulletin. This procedure is also published in the owner manual.
Claim Information
For vehicles repaired under this service update, use:
Labor Operation
Description
Labor Time
Y0150
Reprogram RCDLR and RKE Transmitter
0.6
Y0151
Reprogram BCM, RCDLR, and RKE Transmitters
0.9
Add: Test & Charge Battery
0.2
Add: Test & Replace Battery
0.4
Programming Remote Keyless Entry Transmitters Using the Driver Information Center (DIC)
All of the transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed at the same time, including the one programmed at the dealership. Those transmitters not programmed at the same time will not function properly. Follow the procedure below for programming. This procedure is also published in the Owner Manual.
RELEARN REMOTE KEY
The Driver Information Center (DIC) display allows you to match the remote keyless entry transmitter to your vehicle. To match a remote keyless entry transmitter to your vehicle, do the following:
Press the vehicle information button until RELEARN REMOTE KEY displays.
Press the set/reset button.
Press and hold the lock and unlock buttons on the first transmitter at the same time for approximately 15 seconds.
On vehicles with memory recall seats, the first transmitter learned will match driver 1 and the second will match driver 2
To match additional transmitters at this time, repeat step 3 with each new transmitter. Each vehicle can have a maximum of eight transmitters matched to it.
To exit the programming mode, you must cycle the key to the OFF/LOCK position.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
