4 WD Switch
Hi,
After reading all post on problems with 4 WD switch on my 1999 Chev. Silverado I followed instructions on removeing it. All connections looked good. I took it out and sprayed all connections with moisture barrier and electrical lubricant. I put it back in. I tried all drives and everything work!
THANK YOU
Walter
HOPE THIS CAN HELP SOMEONE ELSE :banghead::jester::D:crackup:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
