Anyone had front diff problems?
i know my dads 04' gmc 2500hd blew the rear carrier and ring gear in half and snapped the pinion. i wish i would have gotten pics. as for the front never heard of anything
matt
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
