volt meter needs adjusting
squarewheels
Hi all,
I have a ’93 GMC diesel 3500 with an inaccurate volt meter. The volt meter reads about 16 volts with the engine off and 19+ when the engine is running. It’s been like this since I bought it a year ago and I’ve finally gotten tired of seeing the meter in the red while driving. Is there a way for adjusting the volt meter to make it more accurate?
Thanks,
Steve
could be reading correctly!
put a meter across the battery terminals and compare your reading to the cockpit volt meter.
Hi all,
Thanks,
Steve
Here is what I got when I measured the voltage
Engine off and after the glow plugs turned off:
12.40 volts at the batteries.
16 volts on the instrument panel gauge.
With the engine running:
14.10 volts at the batteries
18 volts on the instrument panel gauge.
BTW – the instrument panel gauge graduations appear to be in increments of .7 volts.
Thanks for any, and all, help you can provide.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
