Rear End/Drivetrain Issue
About 6 months ago, I would take off and my driveshaft would spin but the truck wouldn't move. And then after a few seconds, it would lock in and really jerk forward. I recently changed the rear end oil hoping that would solve it.
Well, it helped until yesterday.
I was cruising on the highway 65-70 mph and had to slow down for a traffic light. I came to a stop at the light, but there was this horrible loud noise and I think it was my driveshaft still spinning, eventhough I was stopped. It did this for about 5 seconds, and then all of a sudden the rear end locked in and made a loud noise and jerk and I initially thought the car behind me tapped me.
A little later, I was in the median turning left and I hit the gas but the shaft just spun again and then it locked in after about 2 seconds and jerked me forward.
I'm fixing to take it in to the dealer and see if they can figure it out.
Can anyone give me any ideas?
Sounds more like a transmission issue. If it were a ring/pinion problem, you would hear the grinding and feel the jerking every time it would make a full rotation. I would look toward the torque converter. When you say the drive shaft is spinning, is that an observation or assumption?
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
