Replaced Driveshaft
I was having a slight problem with a vibration or shudder when I would take off from a standing start.  A few times it was rather severe, and it was more noticable when I was carrying a load or towing.  I presented the TSB to my friends at Bissett Chevy where I bought the truck, and they ordered me a new 1-piece drive shaft to replace the 2-piece drive shaft and carrier bearing in my truck...
They had to cut the carrier bearing out of the crossmember and I think they did a fine job, and to top it off they took less than 2 hours for the total job.
Here is a shot of where the carrier bearing used to be...
Cool, at least they didn't cut a big chunk out of the cross memeber itself, like I seen happen to another guy.  :thumbs:
I saw those pics too....  I think he got a new truck for that didn't he???
BTW, so far this seems to be an excellent solution to my problem, and it must be the reason the '02's have the one piece shaft in them...
Yeah.  I think it took him a few months to get it all worked out, but got a little nicer truck at no extra cost to him.  :D
Wow! I had no idea the 2500's had Two Piece drive shafts!
The 01's had them.  I don't know which models had them, but obviously the crewcabs did.  The '02 crews have this bigass Aluminum shaft  ;)
Shaners,
Could you explain the "shudder" some more?  I have a noise coming from underneath my '02 Crew Cab short bed with the 2-piece drive shaft.  It sounds like someone knocking on the underside when accelerating across a rough surface.  I can even feel it through the floor board.  If I let off the throttle it goes away which tells me it has something to do with torque caused by acceleration.  I also hear it if I hit a big bump even if I'm not accelerating.  I do NOT hear it if I'm on a real smooth surface.  I have ruled out slapping leaf springs or loose shocks and I've looked over the underside and checked all the nuts and bolts and can get to to make sure they are tight.  Could it be play in the carrier bearing housing?  Any other ideas?
Thanks!
Hutch
I have a 2000 2500 silverado ext cab that came from factory with a one piece drive shaft :ooh: I wonder why some came with a two piece :O
My '02 4x4 HD crew cab came with the 2 piece. :)
Need to get a 1 piece, as my truck does have the takeoff shudder.
Hutch,  It was a seat of the pants feeling.  You culd feel a vibration under your butt when you took off at moderate acceleration.  It was a "shudder" type vibration and wasn't always noticable...  A couple of times it was violent enough that I could get some "slap" out of the rear springs.
The carrier bearing is mounted in a rubber shell, and as torque is applied to the drivetrain the driveshaft will begin to oscillate in this rubber mounted bearing.  It is worse on harder acceleration, and when towing/hauling...
Now that I have a new driveshaft it surprises me at how smooth the truck will "launch".
I hope this helps...
This is what I got from the National Highway Transportation Association.  (NHTSA.com)
Make:  CHEVROLET TRUCK  Model:  K2500  Year:  2001
Service Bulletin Number:  010417001B  Bulletin Sequence Number:  629 Date of Bulletin:  03/02
NHTSA Item Number:  629551
Component:  POWER TRAIN:TRANSMISSION:AUTOMATIC
Summary:
SUBJECT REGARDING LAUNCH SHUDDER ON ACCELERATION (INSTALL NEW ONE-PIECE PROPELLER SHAFT) *JG
Hutch, don't know of this helps, but I noticed w/ relative's 2-piece, that the "shudder" was at the very first application of the throttle for a second or 2, and it got worse both in duration and intensity, at least in the case I'm mentioning, when the truck was pulling or hauling a load, ie - 5th wheel.  This was to the point that the IP shook violently!  The 1-piece cured it completely.
There is a separate issue with spring slapping when hitting irregularities, but this can occur independently from accelerating or not, but sounds like you've ruled that out.
The seat of the pants shake/vibration description by Shaners is exactly right.
I have a two piece drive shaft on my 2002 GMC 2500HD, extended cab, short bed, two wheel drive. I had a similar problem, but it was a "klunk" noise when I would first excellerate. It went to the dealer three times. They did a number of things like lubricating the splines, adjusting the srings, etc, etc, etc. It is much better now, but not perfect. When I tow my fifth wheel, I don't have the problem. Just a comment.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
